Notmally I can see a whole lot of command icons below the comands line (i.e. below File, Edit, View, .....Help). For some mysterious reason (perhaps I inadvertently pressed something) it has all gone and I can not see in help how to turn all the ribbon comand icons back on again.
Solved by pendean. Go to Solution.
Solved by cadffm. Go to Solution.
AutoCAD support?
You are in a public User Forum (hosted from AutoDESK, but a User Forum),
so we are all 'just users like you - some with more and some with less knowledge.
Read your AutoDESK LT - Help [F1]
about how to controle display ribbon <clickmenow>
Sebastian
