AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
reinstall, title block
5 REPLIES 5
342 Views, 5 Replies
It is dumb to have to reload AutoCad LT for Mac everytime backup on external drive. Aslo simple steps in adding title blocks to the 5 standard drawing sizes, and slso not loosing the layer information.
5 REPLIES 5
maxim_k
Welcome to the Autodesk Forums!
Is it a question or a statement? If it is a question, than what do you mean? Could you clarify?
One of the ways:
Create drawing file with objects (lines, polylines, text, etc.) that compose your title block. You can use different layers in this drawing, if you need them. Than use INSERT command in drawing file with standard drawing sizes and use "Browse" button to find file you created in first step. Verify that "Explode block" is un-checked and insert this block into the drawing with standard drawing sizes.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
reinstall after backup on external drive why do I have to reinstall AutoCad LT for Mac 2013? I am not sure what is happening it seems the backup takes place but occasionally when I sign into my I Mac I am given 4 choices I do not have any way of closing the window and I choose to dump the Mac hard drive to my external drive which erases the Mac drive when I reload off the external drive I do not understand why I should have to do anything since the backup takes place automatically onto my external drive?
David H. Bachman
maxim_k
Hi David,
What application do you use for automatic backup?
Is it Time Mashine, or some third parity application?
What are those 4 options during Mac login?
Do you use encrypted hard drive? And which Mac OS do you have on your Mac?
When you boot after restoring from backup:
- you can not launch AutoCAD, while it is installed on your Mac?
or
- AutoCAD seems is not installed at all on your Mac?
Where you purchased AutoCAD? MAS or Autodesk?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
An additional question:
Does it happens frequently (restoration from backup)? Or it was only once?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
>>>... I choose to dump the Mac hard drive to my external drive ...<<<
Why do you do that? That's no way to back up a PC, you are for all practical intents and purposes unloading your harddrive; not backing it up.
Please answer Maxim's questions and identify what app you are using for this unusual/out-in-left-field backup method.
Forma Design Contest
Technology Administrators
