Tried to print to (from Autocad 2020 LT):
Epson WF-7720
CUTEPDF
and ADOBE PDF
and received the same message for all 3 printers with no warnings or messages. Other drawing files print fine. I tried printing from both model and paper space.
Job: - Error(s) Did Not Plot
Job ID: 11
Sheet set name:
Date and time started: 10/2/2019 2:21:53 PM
Date and time completed: 10/2/2019 2:22:00 PM
UserID:
Profile ID: <<Unnamed Profile>>
Total sheets: 1
Sheets plotted: 0
Number of errors: 0
Number of warnings: 0
Sheet: Russell Elevation-Layout1 - Error(s) Did Not Plot
File: C:\Users\Owner\Dropbox\Projects\Russell\Russell Elevation.dwg
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
Thanks...
Solved by Alfred.NESWADBA. Go to Solution.
If that happens only for one drawing file then start AutoCAD, create a new drawing, start command _RECOVERALL and select this file, and see if AutoCAD finds errors within this file, and try plot again.
If that does not help then please show us that dwg-file.
- alfred -
