AutoCAD LT Forum
"did not plot" with no warnings or messages
3 REPLIES 3
jhllywd
864 Views, 3 Replies
Tried to print to (from Autocad 2020 LT):
Epson WF-7720
CUTEPDF
and ADOBE PDF
and received the same message for all 3 printers with no warnings or messages.  Other drawing files print fine.  I tried printing from both model and paper space.
Job: - Error(s) Did Not Plot
Job ID: 11
Sheet set name:
Date and time started: 10/2/2019 2:21:53 PM
Date and time completed: 10/2/2019 2:22:00 PM
UserID:
Profile ID: <<Unnamed Profile>>
Total sheets: 1
Sheets plotted: 0
Number of errors: 0
Number of warnings: 0
Sheet: Russell Elevation-Layout1 - Error(s) Did Not Plot
File: C:\Users\Owner\Dropbox\Projects\Russell\Russell Elevation.dwg
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
Thanks...
3 REPLIES 3
pendean
in reply to: jhllywd
Reset LT2020 https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Install the required 2020.1 update first. Restart your PC.
Now test it with only one of the 5 core PDF drivers provided with LT2020 from Autodesk (like DWG TO PDF.PC3 file): still have an issue?
Alfred.NESWADBA
If that happens only for one drawing file then start AutoCAD, create a new drawing, start command _RECOVERALL and select this file, and see if AutoCAD finds errors within this file, and try plot again.
If that does not help then please show us that dwg-file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
jhllywd
in reply to: Alfred.NESWADBA
RECOVERALL worked! thank you
Forma Design Contest
Technology Administrators
