AutoCAD LT Forum
Quick access layer pull down
4 REPLIES 4
662 Views, 4 Replies
Having an issue.  The quick access toolbar which pulls down layers.  Normally you select object and it is displayed in the layer bar showing color and layer name.  You can then modify or change layer using pull down.  This stopped working.  Anyone ever hear of this and can help I would appreciate it.
Thank you
4 REPLIES 4
pendean
Stopped working means what exactly?
Are your PICKFIRST and PICKADD variables set to the defaults listed in HELP for both? They need to be.
It would not change to the object you select on.  It would just stay on the layer in use.  Pretty rendered useless.  I figured it out.  then in selection mode check box Noun/verb selection.  That fixed the issue.
<OPTIONS><SELECTION>CHECK Noun/verb selection
steven-g
Just a quick tip, that's what PICKFIRST does, mentioned above by @pendean but good to know you found it another way
Forma Design Contest
Technology Administrators
