Poly Lines Width Not showing up in Plotted PDF
Message 1 of 12
Poly lines show up fine in model space, and in paper space.  However, when I plot to a PDF the line weights disappear in the PDF.  Also,  Hatch boundaries turn render blocky (similar to a pixel), and are not smooth and continuous as in model space.
I have done the following:
Fillmode is 1
Layout Vport is not hidden
VSCurrent is 2dwire
UCS World & PLAN
Also, one of my layers is plotting the polyline width, however the others are not.  I have checked the properties, and the line weight is set to By Layer.
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Are your PLINEs on noplot layers?
Plot style table selection is incorrect overall?
LWEIGHT setting too heavy for the one PLINE width?
Message 3 of 12
The poly lines are on plottable layers,  the plot style table in correct I believe, and have selected different options from the plot manager prompt.  The line weights are set to default per layer manager.
Its odd because some of the p-lines will plot with a width, however the others do not.  Also, the hatching on the turn arrows is not smooth and continuous (solid), it is blocky.
Message 4 of 12
pendean
Community Legend
Community Legend
Can you share you actual DWG file?
Message 5 of 12
Attached is the drawing file with the pertinent layers included.
Thank you for looking at this for me.
Nathan
Message 6 of 12
pendean
Community Legend
Community Legend
Thanks for the DWG file: what I see in your file with your chosen PDF driver is what I see plotting out here (see #1), what exactly is missing?
I did notice you have layer 0 frozen and off, always a bad idea in AutoCAD: changing it though make no difference (see #2).
Message 7 of 12
cadffm
@Anonymous
~750 plines with Startwidth /=0
and there are more of them, nested in ARRAY objects.
Most of them with a width of 0.5 Units.
You plot with a scaling factor 0.00230602 (your viewport)
0.5 width scaled by 0.00230602 viewport-scale = 0.001153301 Units/Inch, incredible small, or?
to smal for the PDF resolution and very very to small for a printer.
Another thing, offtopic:
Why you have so much "doubled lines" ? "all" Lines&Arcs are double
Sebastian
Message 8 of 12
Pendean,
That is what I am seeing with the PDF's.  Issues with printing/plotting
1)  Hatch for turn arrows show up blocky (zoom into the plotted PDF)
2)  Pavement lane markings are showing up as lines and not poly-lines with a width.
   *  However, Polylines with a width of 0.5 do not show up with a width
   *  Polylines for crosswalks show up with a width,  their drawing width is 1.25, or 1.5 model space)
3)  The duplicate lines per area layout were wiped out with command OVERKILL.
Note:  Only layers of concern are labeled starting with.  PVMT-MARKINGS
Thanks for the help.  Obviously I am not an advanced AutoCAD user, and trying to learn more to become a proficient drafter.
Nathan
Message 9 of 12
Sebastian,
What is odd about this plot:
1)  The hatched turn signals do not show up smooth, but rather blocky.
  *  zoom into pavement markings for further detail.
2)  Some polylines for pavement markings show up with their respective width, and others do not.
  *  See cross walks.
3)  Only layers of concern are the layers labels (PVMT MARKINGS).
Nathan
Message 10 of 12
cadffm
@Anonymous  schrieb:
Sebastian,
   Is a question of resolution. See my example Layout with a detail-viewport.
  *  See cross walks.
     Because they are widther. By this resolution the width comes out by width 0.9-1.0 and higher.
     Check out my sample where i copied some Plines, I changed the width to 0.6-0.9 and only 0.9 and more will display well.
   Sorry, i don't understand this.
Sebastian
Message 11 of 12
cadffm
forgotten.
Sebastian
Message 12 of 12
Thank you for the help solving this issue.  I appreciate you taking your time and effort to help me out!
Nathan
