Plotting in Model Space
When I plot in model space my drawing jumps off the page.
Here is a screen shot. What's going on?  I cannot figure it out.
these are my plot settings
rkmcswain
The "What to Plot" is set to "Display", which can vary each time you go to print. If you must print from Model Space, then either select a print window or use a named view for best results.
pendean
Community Legend
Community Legend
When you choose DISPLAY for what to plot, you tell AutoCAD you really don't care about the result.
Use something more deliberate and more in control, if you want control: and watch that preview and offsets, they are telling you something important (red lines means you'll have shifting going on) like you're not going to like the results.
BTW why the old tired legacy troublesome "adobe pdf" driver? Try a PDF driver from your current installation software instead, like DWG TO PDF.
HTH
Ok, here are my plot settings now
And my drawing is completely gone off of my model space box
rkmcswain
No, no.  Who said to use "Extents"?
Use the "Window" or "View" selection for "What to Plot"
Better yet, print from a layout, and set the "What to Plot" to "Layout" and forget about all of this nonsense of even having to set this.
Valentin_CAD
@Anonymous ,
I recommend you start using the Page Setup Manager.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
Share your DWG file with us please, I fear you may be missing way more than you think or are explaining here.
