- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I posted this before, and tried the solutions provided. I still have had no luck with this issue. I again am reaching out for some help.
So the issue is whenever I try to PDF any document, the output places the PDF in the bottom left.
I have since done the following:
1. Soft reset my computer (keep personal files, delete all apps and settings).
2. Hard reset my computer (delete all files, delete all apps and settings).
3. I learned along the way that if I download AutoCAD onto another computer, log in with my credentials and try PDFing, the issue still persists.
Three pictures are attached.
First picture is a picture of a blank rectangle in the middle of paper space layout.
Second picture is the plot settings. The only input I made is the plotter choice. Which in this case is "AutoCAD PDF (General Documentation).pc3".
Third picture is the output that preview provides.
This was replicated on my second computer. All under the default AutoCAD install settings (for both). No plugins from any other program was involved, as this is the first thing I installed after a hard reset.
I also replicated this process (hard wipe - download autocad - log in - plot) for AutoCAD 2020, 2021, and 2022.
Another thing to mention is that this is occurring across three of my available systems. In-office system, remote work from home system, and my wife's computer which I used to check if the issue persists there too. It did, so my last guess is that maybe there is a plotter setting tied to my Autodesk account? I checked A360, and I have no dwgs or anything else uploaded to the cloud, and could not find any settings that my migrate from computer to computer. Where this ISN'T happening in my office is the other seven drafters on the team. I would try to use their account to try to narrow down my assumptions, but I do not want to "infect" them with this bug if that is the case.
Last thing to mention is that yes I am aware of the workarounds, and have been using them every day. Plotting to window, and centering to plot. Removing everything other than what is on the paper space in the layout, and plotting to extents, and centering to plot.
