AutoCAD LT Forum
Offset tool
6 REPLIES 6
mark
1056 Views, 6 Replies
Offset tool
Does a system variable exist to enable the object you are offsetting to be the same colour as current rather than the colour of the original object from which you are offsetting?
Thanks for any advice or guidance.
6 REPLIES 6
steven-g
in reply to: mark
It's built into the offset command, when you start the offset command look at the command line, you have an option to choose "Layer" which lets you pick either the "Source" layer or "Current" and it keeps that option untill you change it back
rkmcswain
in reply to: mark
No sysvar AFAIK, but the option to do this, is part of the Offset command.
R.K. McSwain     | CADpanacea | on twitter
mark
in reply to: steven-g
Thanks for that it's very useful to know. It doesn't however change the actual properties other than the physical layer the object is on - at least I can't seem to get it to anyhow. Thus if you have objects of a different colour on the same layer then the colour is retained as the source object.
steven-g
in reply to: mark
Indeed that's not an option, but it may be possible if you use a macro
EDIT
^C^Coffset;\\\\e;setbylayer;l;;n;n;
This macro works, unfortunately, the offset command can be run with differing amounts of keystrokes so this macro only works if you pick an offset distance on screen, if you type a number it fails (and would need altering). But the SETBYLAYER command may well help, or maybe not.
pendean
in reply to: mark
It is generally assumed your objects are all set to BYLAYER instead of having individual properties overrides.
Are you trying to maintain the source object's color/linetype in the offset-copy? or reset it all to "bylayer"?
mark
in reply to: pendean
Hi
Thanks for the reply. I just want to maintain the colour of the offset to the current colour rather than have the colour of the original object being offset - even when they are on the same layer.
I see the work around of having separate layers for different colours as suggested previously but I just wanted to see if it was possible to do the above.
Regards
Forma Design Contest
Technology Administrators
