Does a system variable exist to enable the object you are offsetting to be the same colour as current rather than the colour of the original object from which you are offsetting?
Thanks for any advice or guidance.
Solved by steven-g. Go to Solution.
Indeed that's not an option, but it may be possible if you use a macro
EDIT
^C^Coffset;\\\\e;setbylayer;l;;n;n;
This macro works, unfortunately, the offset command can be run with differing amounts of keystrokes so this macro only works if you pick an offset distance on screen, if you type a number it fails (and would need altering). But the SETBYLAYER command may well help, or maybe not.
