I want to chain some move actions with a visibility action so that when I change the visibility state, the attributes move. The reason for this is so that when some of the attributes are hidden, the remaining move so that they are still close to the center of the block.
How do I accomplish this?
Thank you!
Solved by imadHabash. Go to Solution.
You need to set the attribute to locked and then the move action can move it.
Also you will find more help in the Dynamic block forums https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Howard Walker
