I can't insert multiple model-space drawings into a paper-space sheet. There is no "box" around the ms drawing which, in previous versions, was what you copied. I'd appreciate any help!
Solved by cadffm. Go to Solution.
you never insert model-space drawings, you created copies of VIEWPORTs, what a like a whole in the paper to see the model space content.
The command to create such a Viewport is: MVIEW [F1]
See also the content of your ribbon tab LAYOUT, while in Layouts..
>>"which, in previous versions, was what you copied."
Nothing changes.
Check out LAYOUTCREATEVIEWPORT [F1] Should be 1 if you like to get a viewport what will never matchs your needs.
Sebastian
