AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
MIRRTEXT keeps resetting itself
3 REPLIES 3
c.cumbers
1491 Views, 3 Replies
Hello, whenever I use the MIRROR command on drawing items including text and MIRRTEXT is set to 0 it changes itself and then a warning appears bottom right of screen telling me that a system variable has changed. I open the System Variable Monitor and reset MIRRTEXT but it changes again when I us MIRROR on text. Is there a way to lock the system variables?
Many thanks Chris
3 REPLIES 3
pendean
in reply to: c.cumbers
Is the problem related to only one DWG file, or all of your files, even if you start a new file?
Your LT version is...?
c.cumbers
in reply to: pendean
Hello
It seems to happen on most drawings. I have LT 2019
pendean
Not seeing it here in AutoCAD/LT 2019 in our office.
Remove MIRRTEXT from your SYSTVARMONITOR list, set it to 0 that you want, SAVE your file twice, then test again. Does it still change? If yes, MIRRTEXT is a system level variable, is your Windows log-in very restricted?
Forma Design Contest
Technology Administrators
