AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Maps with high resolution
2 REPLIES 2
902 Views, 2 Replies
I am fairly new to this program and don't know much about it. I need to download a map, with a high resolution, and insert it into AutoCAD. How do I do this? The map I can access through AutoCAD isn't good enough. I need a map that's similar to Google Earth or at least google maps.
2 REPLIES 2
pendean
IMAGEATTACH command if the file format is one supported by your LT version.
I'd suggest Plex.Earth to import images from Google Earth to AutoCAD, but I doubt it runs in LT, because LT (as I guess you already know) doesn't support plugins.
Anyway, you can take a look and ask them if they can suggests you something.
https://plexearth.com
Forma Design Contest
Technology Administrators
