I have tried to edit a hatch pattern 3 times in LT 2019 and each time LT crashes, Any ideas why this is happening its driving my up the wall.
Solved by john.vellek. Go to Solution.
Solved by pendean. Go to Solution.
Hi @Anonymous,
Please let me know of the results. Also, do you happen to have any Object Enablers installed?
If the problem persists, please submit a CER report and give me the number to see if it lists the cause of the crash. Otherwise, if this is not unique drawings bu tall drawings, please prepare a NFO for me to look at.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
Thanks for the suggestions it appears at the moment that it has helped by doing an audit and re-saving the drawing. It appeared that their were 3 errors that were dealt with when i ran the audit.
