Dear Henk
Here are some solutions which may help you get to the bottom of this:
Unhandled Access Violation Exception error messages
http://www3.autodesk.com/adsk/support/techdoc/0,,226973--273818-0_21837,00.html
Try using recover to open the drawing.
http://www3.autodesk.com/adsk/support/techdoc/0,,81224--125452-0_21837,00.html
If this does not fully recover the drawing you could look at the solution
at:
http://www3.autodesk.com/adsk/support/techdoc/0,,86662--125452-0_21837,00.html
You might like to look at this solution regarding how to avoid
corruptions
http://www3.autodesk.com/adsk/support/techdoc/0,,200194--273818-20022_21837,00.html
Best Regards
Samantha Babister
Product Support Representative
AMG Product Support UK
Worldwide Support & Services, Autodesk
Henk Vermaas wrote:
> During
> normal drawing commands the following error reveals: Fatal error:
> Unhandled access violation exception at 33a08034h. After this error
> autocad shuts down and damaged the drawing file. by reopening the
> drawing autocad is trying to recover the file and succeded, But can't
> find errors. But afther that we are still not alble to open the
> drawing file. During regeneration of the file the error occures again
> Pleas Help!!!!!! "
