AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Looking for the location of imported linetype
28 REPLIES 28
Message 1 of 29
jeff_wine
1221 Views, 28 Replies
Hey everyone, I'm looking to modify a linetype that that was imported from another file I received from another company. I have learned how to make linetypes in the past and I know where the acad.lin file is, but when I look at the file for a linetype I know exists in my drawings, I cannot find the one I want to modify. I don't want to start from scratch making a line, when I could copy/paste an existing line description and change one small thing for the line I want. I'd like to keep everything else about the existing line because they represent a similar thing with a slight change.
From a sample drawing that was sent to me, I copy/pasted a new linetype from the supplied file to my template file, so now I have that linetype with every new drawing, but have no idea where ACAD stores that info if I can't find it in that acadlt.lin file.
28 REPLIES 28
Message 21 of 29
hwalker
in reply to: jeff_wine
Have you put a hard return at the end of the .lin file?
Howard Walker
Left Handed and Proud
Message 22 of 29
paullimapa
this is how it looks like when I use both 24F and modified 144F but I'm running acad and not LT
try opening attached dwg in LT and see if you're able to use the 2 attached linetype definitions to create the same in LT. Also may be a better idea to keep these and any custom linetypes separate from the default acadlt.lin location since you may lose this when you upgrade to the next version.
Paul Li
IT Specialist
@The Office
Message 23 of 29
jeff_wine
in reply to: hwalker
No, I don't think i did a "hard" return at the end. But with the new command _LINETYPE in LT version 2024, I feel like that shouldn't matter, and I would think with a built in command, it would take care of placing it correctly in the .lin file
Message 24 of 29
hwalker
You need to put a hard return at the end of the .lin file. Never assume that it will automatically be done for you
Howard Walker
Message 25 of 29
jeff_wine
in reply to: paullimapa
Thank you SO MUCH! this does it for me, for what I need. I will try to figure out what I did wrong with entering the information, but what you sent works great!
Message 26 of 29
jeff_wine
Thanks for your help, everyone.
Message 27 of 29
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Message 28 of 29
vladimir_michl
in reply to: cadffm
For some complex linetypes, LINOUT needs access to the source shape file (SHP, not just SHX) to decode the name of the shape. But generally, LINOUT works also in AutoCAD LT (2024 and on).
If you have a DWG (and SHX/SHP) where LINOUT fails, please send it to me to try to find a fix.
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 29 of 29
doliktertok891
 Data corruption in the file, possibly due to a large number of Registered Applications (regapps) being present. Missing font that a linetype references. The graphics card driver is out of date.
Forma Design Contest
Technology Administrators
