Hi guys, I am having a problem with linetype scale.
I have large project which I inherited from another practice and we have each section, plans... into different files. I can't find a way to make the linetypes to look the same. I have already check the ltscale, msltscale, psltscale, aready reloaded the linetypes and global scales are the same. I can't think of anything else....
Any ideias????
Solved by Leticia_Campanelli. Go to Solution.
sorry, wrong thread Centimeter(1) / Inch (2.54) = 0.393700787401575
>>"I can't find a way to make the linetypes to look the same."
>>"I have already check the ltscale, msltscale, psltscale*, aready reloaded the linetypes and global scales are the same."
*please, first we should talk about the model tab ONLY.
Make sure msltscale is set to the same, if ON(1), then make also sure CANNOSCALE is the same(same scalefactor).
>>"I can't think of anything else...."
The problem is: We know how, but only you have the data... 😉
Upload both files with minimum one example object per file,
this way we can check the settings and properties and
can we can say what happens.
Q: And there is not a pagesetup which use different plotstyles (show plotstyles) setting?
Sebastian
Hi guys,
I have them all set to 1.
I think there was a glitch in the system, it all seems fine today.
thanks anyways.
