AutoCAD LT Forum
Linetype appearence in diferent files
3 REPLIES 3
Leticia_Campanelli
349 Views, 3 Replies
Hi guys, I am having a problem with linetype scale.
I have large project which I inherited from another practice and we have each section, plans... into different files. I can't find a way to make the linetypes to look the same. I have already check the ltscale, msltscale, psltscale, aready reloaded the linetypes and global scales are the same. I can't think of anything else....
Any ideias????
3 REPLIES 3
cadffm
in reply to: Leticia_Campanelli
sorry, wrong thread Centimeter(1) / Inch (2.54) = 0.393700787401575
>>"I can't find a way to make the linetypes to look the same."
>>"I have already check the ltscale, msltscale, psltscale*, aready reloaded the linetypes and global scales are the same."
*please, first we should talk about the model tab ONLY.
Make sure msltscale is set to the same, if ON(1), then make also sure CANNOSCALE is the same(same scalefactor).
>>"I can't think of anything else...."
The problem is: We know how, but only you have the data... 😉
Upload both files with minimum one example object per file,
this way we can check the settings and properties and
can we can say what happens.
Q: And there is not a pagesetup which use different plotstyles (show plotstyles) setting?
Sebastian
What are the settings for LTSCALE, MSLTSCALE and PSLTSCALE in all of the files? "checking" tells us little. 1 for all is a good place to start.
What are the annotative scale settings for each file? CANNOSCALE command.
What are the MEASUREMENT variable settings in each of those files? They need to match too https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Hi guys,
I have them all set to 1.
I think there was a glitch in the system, it all seems fine today.
thanks anyways.
Forma Design Contest
Technology Administrators
