AutoCAD LT Forum
Lines are not highlighting/glowing blue when hovering or selected.
14 REPLIES 14
Message 1 of 15
JoeGXWXU
4839 Views, 14 Replies
Please help.
I have recently reformatted my windows laptop. Since reinstalling Autocad LT I have been having issues with hovering and selecting in model space. When I hover/select a line it no longer glows blue. When I hover, only the ends of the lines glow. When I select the line, only the nodes and grips highlight. I have attached an image to show what I mean.
The only info online I have found relates to the SE
LECTIONEFFECT & PRESELECTIONEFFECT commands. This is not the problem I am having, but I cannot find anyone online who has had the same problem!
If anyone has any ideas, please let me know. I have already tried uninstalling and reinstalling Autocad, but that didn't work...
14 REPLIES 14
Message 2 of 15
JoeGXWXU
in reply to: JoeGXWXU
I have fixed it! It turns out that Autocad was using the incorrect graphics card... I changed the settings to make sure it always uses the high performance graphics card and voila... problem solved.
Hope this helps someone else
Message 3 of 15
i have same problem but that graphics card setting didnt help... This is really annoying.
Message 4 of 15
@jaakko_hakomaki9FBLZ share with us screenshots of your ABOUT and GRAPHICSCONFIG command pop-ups, as well as information about your Operating system version please.
If you've never done screenshots before, explore this link Use snipping tool to capture screenshots - Windows Help
Message 5 of 15
@pendean
My computer is Lenovo thinkbook 14 gen4
Message 6 of 15
For me, the setting I had to change was in my computer setting
Message 7 of 15
@JoeGXWXU
Yes i have also done that. Didnt help
Message 8 of 15
Start here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-crashing-w...
Then... Have you installed the 2022.1.3 / 2023.1.3 2024.0.1 Update yet (you forgot to share your ABOUT command pop-up)? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart your AutoCAD variant: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
Message 9 of 15
@pendean
Any of those didnt help me...
I have the latest version (Autocad LT 2024.0.1)
What is GFXDX12? How do I change that?
Message 10 of 15
@jaakko_hakomaki9FBLZ turning off GFXDX12 means https://help.autodesk.com/view/ACD/2024/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-make-AutoCAD...
You just type it at the commandline to change it's setting: AutoCAD is 40-ish years old, you still have to TYPE commands at the commandline when you cannot find them as a button or much else.
HTH
Message 11 of 15
@pendean
Thank you!! It's working now!
Message 12 of 15
disciplinaplus
Hello!
I found the solution (Autocad LT 2025.0.1) by typing SELECTIONEFFECT at the commandline, setting variable to 0.
Message 13 of 15
ayush05m
in reply to: disciplinaplus
Indeed it can solve the selection problem but still persists the hovering issue
Message 14 of 15
j_denheijer
This works perfectly in our VDI 👍
Message 15 of 15
Thx... It worked in LT 2024 also....bt we have to put the value to 1 instead of 0
Technology Administrators
