Lines are not highlighting/glowing blue when hovering or selected.
JoeGXWXU
Message 1 of 18
JoeGXWXU
Please help.
I have recently reformatted my windows laptop. Since reinstalling Autocad LT I have been having issues with hovering and selecting in model space. When I hover/select a line it no longer glows blue. When I hover, only the ends of the lines glow. When I select the line, only the nodes and grips highlight. I have attached an image to show what I mean.
The only info online I have found relates to the SE
LECTIONEFFECT & PRESELECTIONEFFECT commands. This is not the problem I am having, but I cannot find anyone online who has had the same problem!
If anyone has any ideas, please let me know. I have already tried uninstalling and reinstalling Autocad, but that didn't work...
Replies (17)
Message 2 of 18
JoeGXWXU
I have fixed it! It turns out that Autocad was using the incorrect graphics card... I changed the settings to make sure it always uses the high performance graphics card and voila... problem solved.
Hope this helps someone else
Message 3 of 18
jaakko_hakomaki9FBLZ
Observer
Observer
i have same problem but that graphics card setting didnt help... This is really annoying.
Message 4 of 18
pendean
Community Legend
Community Legend
@jaakko_hakomaki9FBLZ share with us screenshots of your ABOUT and GRAPHICSCONFIG command pop-ups, as well as information about your Operating system version please.
If you've never done screenshots before, explore this link Use snipping tool to capture screenshots - Windows Help
Message 5 of 18
Observer
Observer
@pendean
My computer is Lenovo thinkbook 14 gen4
Message 6 of 18
JoeGXWXU
For me, the setting I had to change was in my computer setting
Message 7 of 18
Observer
Observer
@JoeGXWXU
Yes i have also done that. Didnt help
Message 8 of 18
pendean
Community Legend
Community Legend
Start here https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-crashing-w...
Then... Have you installed the 2022.1.3 / 2023.1.3 2024.0.1 Update yet (you forgot to share your ABOUT command pop-up)? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart your AutoCAD variant: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
Message 9 of 18
Observer
Observer
@pendean
Any of those didnt help me...
I have the latest version (Autocad LT 2024.0.1)
What is GFXDX12? How do I change that?
Message 10 of 18
pendean
Community Legend
Community Legend
@jaakko_hakomaki9FBLZ turning off GFXDX12 means https://help.autodesk.com/view/ACD/2024/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-make-AutoCAD...
You just type it at the commandline to change it's setting: AutoCAD is 40-ish years old, you still have to TYPE commands at the commandline when you cannot find them as a button or much else.
HTH
Message 11 of 18
Observer
Observer
@pendean
Thank you!! It's working now!
Message 12 of 18
disciplinaplus
Community Visitor
Community Visitor
Hello!
I found the solution (Autocad LT 2025.0.1) by typing SELECTIONEFFECT at the commandline, setting variable to 0.
Message 13 of 18
ayush05m
Community Visitor
Community Visitor
Indeed it can solve the selection problem but still persists the hovering issue
Message 14 of 18
j_denheijer
Observer
Observer
This works perfectly in our VDI 👍
Message 15 of 18
danish_haider
Community Visitor
Community Visitor
Thx... It worked in LT 2024 also....bt we have to put the value to 1 instead of 0
Message 16 of 18
chadRQ7B8
Observer
Observer
Ok, so if none of the above worked for you (which was my case), I found an option under the SELECTION tab in options that worked for me. Make sure these two checkboxes are checked and your objects should highlight when you hover the cursor over them. Hope this helps.
Message 17 of 18
nikhilCJE22
Community Visitor
Community Visitor
I tried this command - Selectionpreview - set it to 3.
Hope that helps!
Message 18 of 18
nikhilCJE22
Community Visitor
Community Visitor
Try SELECTIONPREVIEW and set it to 3 & HIGHLIGHT to 1. Hope it helps
