AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Layout won't PDF or Print in color
10 REPLIES 10
Message 1 of 11
lroperWW9LT
2004 Views, 10 Replies
My layout is in color, but when I try to pdf or print it, everything inside the viewport turns black and white. However, the border around the viewport appears in color.
10 REPLIES 10
Message 2 of 11
hwalker
in reply to: lroperWW9LT
Please post a screenshot of your plot dialog box so we can see which settings are being used
Howard Walker
Left Handed and Proud
Message 3 of 11
lroperWW9LT
in reply to: hwalker
See attached.
Message 4 of 11
pendean
What is SHADEMODE set to inside your viewport?
Otherwise... Post your DWG file with the problem please.
Message 5 of 11
lroperWW9LT
in reply to: pendean
it's 2d.. I'm unable to upload the drawing itself.
Message 6 of 11
pendean
create a new viewport: does the problem go away?
Message 7 of 11
user181
Uncheck the "Plot with plot styles" option in your plot settings and see if that helps.
Message 8 of 11
lroperWW9LT
in reply to: user181
When I previewed it, it appeared to work, but when I actually saved it and opened the file, it is still black and white within the viewport and only the board colors are there.
Message 9 of 11
lroperWW9LT
Doesn't seem to have done anything.
Message 10 of 11
pendean
Is this a problem with ALL of your files, or just this one?
What changed with your setup or printing recently?
Can you print color from other applications?
Message 11 of 11
steven-g
Can you at least post a PDF so we can see the results, but if this isn't a faulty installation we really need to see a dwg to look at the settings and see if we can reproduce the problem? Even just a simple drawing with a couple of colored objects in a viewport that still prints black and white for you would be sufficient it doesn't need to be a classified drawing.
Technology Administrators
