AutoCAD LT Forum
Layout won't PDF or Print in color
10 REPLIES 10
Message 1 of 11
lroperWW9LT
2395 Views, 10 Replies
My layout is in color, but when I try to pdf or print it, everything inside the viewport turns black and white. However, the border around the viewport appears in color.
10 REPLIES 10
Message 2 of 11
hwalker
in reply to: lroperWW9LT
Please post a screenshot of your plot dialog box so we can see which settings are being used
Howard Walker
Left Handed and Proud
Message 3 of 11
lroperWW9LT
in reply to: hwalker
See attached.
Message 4 of 11
pendean
What is SHADEMODE set to inside your viewport?
Otherwise... Post your DWG file with the problem please.
Message 5 of 11
lroperWW9LT
in reply to: pendean
it's 2d.. I'm unable to upload the drawing itself.
Message 6 of 11
pendean
create a new viewport: does the problem go away?
Message 7 of 11
user181
Uncheck the "Plot with plot styles" option in your plot settings and see if that helps.
Message 8 of 11
lroperWW9LT
in reply to: user181
When I previewed it, it appeared to work, but when I actually saved it and opened the file, it is still black and white within the viewport and only the board colors are there.
Message 9 of 11
lroperWW9LT
Doesn't seem to have done anything.
Message 10 of 11
pendean
Is this a problem with ALL of your files, or just this one?
What changed with your setup or printing recently?
Can you print color from other applications?
Message 11 of 11
steven-g
Can you at least post a PDF so we can see the results, but if this isn't a faulty installation we really need to see a dwg to look at the settings and see if we can reproduce the problem? Even just a simple drawing with a couple of colored objects in a viewport that still prints black and white for you would be sufficient it doesn't need to be a classified drawing.
Forma Design Contest
Technology Administrators
