Layout view dispays in Black & White
Message 1 of 23
For some reason some of my files are displaying as black and white in Layout view. The files display as they should in color in model space. These files contain color layers but the color can only be viewed in Paper space when I select an object and am moving it.
Replies (22)
Message 2 of 23
PAGESETUP command for that layout, uncheck the box for displaying plot styles. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 3 of 23
thanks, but its not showing the original given line thickness which i given in penstyle how to make that one
Message 4 of 23
Charles_Shade
What is your CAD version?
From the Command Line LINEWEIGHT and choose Display Lineweight
Or tap the fat + sign (LWT) in the Tray to turn Lineweight on.
Message 5 of 23
Thanks, its work
Message 6 of 23
hi, i would like to know why even I check the "display plot style" Im not able to see the black and white in my drawing, it is still on colors, what can i do?
Message 7 of 23
pendean
Community Legend
Community Legend
You have the wrong/incorrect PLOT STYLE TABLE selected.
OR
You may also be selecting the wrong type of plot style table: STBs don't work like CTBs for example.
OR
you just forgot to check the box called PLOT WITH PLOT STYLES.
Message 8 of 23
WALEED-131274
Community Visitor
Community Visitor
thanks
Message 9 of 23
Thanks Bro for resolving my issue. keep solving...
Message 10 of 23
This is not solved.  The question, and my current problem, is that the colors do not display in the viewport.  Displaying the lineweight does not work for me.
Message 11 of 23
pendean
Community Legend
Community Legend
Post your DWG file along with your plot style table, let's all have a look for ourselves.
Message 12 of 23
rkmcswain
@Anonymous - have you checked the third item in post #7 of this thread. That is what your issue sounds like.
Message 13 of 23
shabee.fatima
i have autocad 2013 and my layout window doesnot open like others as a white window and i can`t plot to scale
Message 14 of 23
pendean
Community Legend
Community Legend
Share screenshots of what you see and your source DWG file too.
Message 15 of 23
shabee.fatima
Message 16 of 23
shabee.fatima
Message 17 of 23
pendean
Community Legend
Community Legend
What happens if you click on LAYOUT2?
What happens is you start a new file, then INSERT this file into it, then click on LAYOUT1 in that new file?
FYI AutoCAD2013 is not supported in Windows 10, hope that's not the real problem http://autode.sk/1IY4C2X
Message 18 of 23
shabee.fatima
the same thing happens in new file as well.
i have been using autocad 2013 in windows 10 always
Message 19 of 23
pendean
Community Legend
Community Legend
Can you share your DWG file here please?
>>>..using autocad 2013 in windows 10 always...<<<
FWIW you simply lucked out so far: one day it will stop working,so have a backup plan ready as no one at Autodesk will help and your clients will not accept the excuse.
Message 20 of 23
shabee.fatima
Here is the dwg file
okay then maybe autocad 2015-17 will work with windows 10?
