Solved by Charles_Shade. Go to Solution.
thanks, but its not showing the original given line thickness which i given in penstyle how to make that one
What is your CAD version?
From the Command Line LINEWEIGHT and choose Display Lineweight
Or tap the fat + sign (LWT) in the Tray to turn Lineweight on.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
hi, i would like to know why even I check the "display plot style" Im not able to see the black and white in my drawing, it is still on colors, what can i do?
This is not solved. The question, and my current problem, is that the colors do not display in the viewport. Displaying the lineweight does not work for me.
i have autocad 2013 and my layout window doesnot open like others as a white window and i can`t plot to scale
the same thing happens in new file as well.
i have been using autocad 2013 in windows 10 always
Here is the dwg file
okay then maybe autocad 2015-17 will work with windows 10?
