I tried importing a autoCAD drawing file into a program called pool studios that is compatible with autoCAD and it says there was an error. I only have autoCAD lite and didn't know if that was a restriction in autoCAD lite or if there were other issues?
Solved by Emmsleys. Go to Solution.
Hello @Anonymous,
Welcome to the Autodesk community!
A few questions for you to get a better idea of what suggestions to offer:
What release of AutoCAD LT are you working with 2018?
What version or product release are using for the pool software, is it the most recent release?
Post back in the thread if you have any other questions.
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
To add for the benefit of other user's who might have a similar question or issue.
An option could be;
