Autocad LT 2013 error at first command
Good morning, use autocad lt 2013 on upgraded windows 10. At start it opens and the first command (whatever) quits unexpectedly and triggers the autodesk error sending. I tried to fix it and re-install it but it does not work.
I ask for help
Thanks for your attention
rkmcswain
AutoCAD LT 2013 is not supported on Windows 10, although it may run okay with some known issues.
So was AutoCAD LT 2013 installed on this PC first (with an older O/S) and this problem started when the O/S was upgraded to Win10?
R.K. McSwain     | CADpanacea | on twitter
Exactly, I used windows 7 and with windows 10 worked. Then with the various
windows 10 updates it started to make fatal error
Is there no way to make it work?
thank you
pendean
Community Legend
Community Legend
You could try these free methods http://www.howtogeek.com/228689/how-to-make-old-programs-work-on-windows-10/
Or this for purchase method http;//www.longbowsoftware.com
Or upgrade AutoCAD/LT.
Emmsleys
HI @Anonymous
As a workaround, if you still want to use AutoCAD LT 2013 you could look at the following suggestions.
Virtual Machine Environment
How to Make Old Programs Work on Windows 10
Or run a trial version of AutoCAD LT 2016, 2017 or 2018. You can grab the download files here: ADSK Virtual Agent
Sarah Emmsley
Technical Support Specialist
Emmsleys
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Smiley Happy
Sarah Emmsley
