Insert multiple columns at X and Y's with Attribute
Hi There,
I'm trying to add over 500 Lighting Columns onto a drawing with its associated number. i.e Block-XXXX
I have an excel spread sheet with all X and Y's in the format of xxxxxx, xxxxxx and use PTManager to import all columns onto the drawing.
I have then associated an attribute to the block, so now all all columns have XXXX next to them. Used the Attout command and then pasted all of the numbers into the set values.
When I Attin, the column numbers are not what they should be for their X and Y counter-part. See below
Is there a fix for this, or a better way to achieve my goal
pendean
Community Legend
Community Legend
steven-g
I think you posted in the wrong forum. LT doesn't have the ATTOUT and ATTIN commands
I did sorry
Emmsleys
@Anonymous,
Were you able to find the correct forum board? If you need help navigating through the Autodesk forums feel free to post back.
I'd be happy to help.
Sarah Emmsley
Technical Support Specialist
