Sometimes when I link an Excel schedule and I want to make any edit or select the table, I find the grips are too big and cover the table and surrounding drawing.
Here is a snapshot of how the table looks:
and here is another snapshot of what happens when I select one cell of the table:
Any idea what is happening and how to fix it? Thanks
Solved by pendean. Go to Solution.
I used the "Link Data" function to link to a specific range of cells in the .xlsx file. Then I create a table and use the data link as an insert option
I'm using LT 2024.1
GRIPSIZE=5
Now I guess the problem is not with the grips themself, but it is with the orange border that appears when selecting a cell or the whole table. Here is a snapshot of normal table in another file that doesn't have this issue. The selection border has a reasonable size.
@marc.khalil Thanks for the additional information plus new screenshots.
I'm not able to replicate the issue here in a handful of DWG files linking to a handful of different EXCEL files. But maybe others can so hang on, I tried a few settings that I can think off but nothing is having the effect you describe.
I apologize for late reply. Life got busy a bit. I'm attaching the file that i have the problem with. I couldn't attach the excel files due to company info and data.
Thanks for the file: I see what you mean quite clearly. May I ask, why your table is a ~1/30th scale of your text STYLE and TABLESTYLE settings in the file? Your "standard named" TABLE text is 2'-9.75" tall, your STYLE setting is 2'-9.75" tall, but your table text is 1" tall.
And by chance, are your other no-problem DWG files with Excel Tables in them also have those settings for STYLE and TABLSTYLE? I'm trying to replicate your issue in my own drawings.
Thanks for your hints. I spent some time investigating the file settings, and testing. Once I changed the table's text style to match the overall sheet, table start to look normal with no issue and I can finally see the cell text.
