Overall dimension not adding to the same amount as broken down dim string
mbetGEGZX
Message 1 of 15
mbetGEGZX
This happens way too often with the program.  The overall dimension of something like a building does not equal the same value as the more detailed dimension string. Even with units and dim styles working with the same precision this remains a problem on past and current drawings. Let me know if anyone out there has a fix or work around.
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Show us please: post a DWG file example with all dimensions in place that do not add up.
Heads up though, this is always a user error either in dimension placement or rounding settings or both.
Message 3 of 15
rkmcswain
Are you talking about something like this?
There is nothing wrong with it, it's just rounding.
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 15
RobDraw
Assuming that it's not bad drafting. It's probably a rounding issue. Boost the precision way beyond what you need to see if the numbers add up.
Rob
Message 5 of 15
mbetGEGZX
Bad drafting? Offset 32' means offset 32' not 31'-11 3/4". Rounding makes more sense therefore the earlier inquiry regarding a work around.
Message 6 of 15
pendean
Community Legend
Community Legend
Show us please: post a DWG file example with all dimensions in place that do not add up. You're not the first to complain then find out it was not true but something else is being missed.
Message 7 of 15
mbetGEGZX
**** - Thought I did that already. Here is the file.
Message 8 of 15
mbetGEGZX
Let me know if this works
Message 9 of 15
RobDraw
Don't get your panties in a twist. I did say assuming it's not bad drafting. Also, we haven't seen your file or know what your capabilities are. Judging by your defensiveness, I'm starting to lean the other way.
Rob
Message 10 of 15
pendean
Community Legend
Community Legend
Thanks for the DWG file: can you explain where we can see the issues you've listed above please?
Here is my quick test after changing some of your precision settings:
Message 11 of 15
steven-g
Try selecting a whole series of dimensions where you see an error, and then change the precision from 1/4" to 1/256" and you can see the difference.
Message 12 of 15
mbetGEGZX
I always thought the less precise would give more leeway and be more forgiving but 1/256" is a crazy fraction that shows exactly where differences lie
Message 13 of 15
RobDraw
You're welcome.
Rob
Message 14 of 15
steven-g
The 'precision' in Autocad is only ever a visual value, internally Autocad keeps the real value to a very high degree of accuracy and this is not affected by any settings. If you use keyboard entry for a line then what you type is respected, but using mouse pick points is a different situation and only as accurate as your precision settings (which can lead to these "crazy" values).
Message 15 of 15
john_coyle344Q3
Community Visitor
Community Visitor
What an unnecessary, incredibly rude response.
