I am making several drawings, all of which will use the same dimension and text styles. How do I import, or copy, styles (mainly dimension styles) from a previous drawing to the new drawing?
I searched for a topic on this, but what I found seems to apply to ACad not ACad LT. Or, at any rate, the topic discussed things I'm not familiar with A-Tall!
Thanks for your help, as usual.
Bill
Solved by hwalker. Go to Solution.
Research using Design Centre.
You can drag and drop styles from one open drawing to another open drawing.
Howard Walker
...and Templates
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
You could also insert the drawing that has the desired dimstyles, layers, etc. into the drawing that you want to have these same dimstyles, etc. After inserting, purge out anything you don't want.
Lowell
Templates
Templates
Templates
I'm not sure but using a TEMPLATE requires nothing to be inserted or dragged or found or ...
I agree, templates are the way to go. Dimstyles, layers, print settings, etc. all setup in a template and used to start a drawing. We have a template for a standard 24 x 36 dwg and metric version of the same thing. We also have a template for an 8 1/2 x 11 sketchpad dwg. They have evolved a bit since I created my first template in AutoCAD release 2.6 back in the 80's but templates are great once you get all the settings correct for you.
Lowell
