AutoCAD LT Forum
Import dimension styles?
8 REPLIES 8
Message 1 of 9
BillW435
39771 Views, 8 Replies
I am making several drawings, all of which will use the same dimension and text styles. How do I import, or copy, styles (mainly dimension styles) from a previous drawing to the new drawing?
I searched for a topic on this, but  what I found seems to apply to ACad not ACad LT. Or, at any rate, the topic discussed things I'm not familiar with A-Tall!
Thanks for your help, as usual.
Bill
8 REPLIES 8
Message 2 of 9
hwalker
in reply to: BillW435
Research using Design Centre.
You can drag and drop styles from one open drawing to another open drawing.
Howard Walker
Left Handed and Proud
Message 3 of 9
Charles_Shade
in reply to: hwalker
Message 4 of 9
pendean
ADCENTER command can be used to copy the following between drawing files (or from your template files): Dimension Styles, Layers, Layouts, Linetypes, Multi-Leader Styles, Table Styles and Text Styles.
Message 5 of 9
BillW435
Thanks, everyone. Got it to work, with your help.
Bill
Message 6 of 9
You could also insert the drawing that has the desired dimstyles, layers, etc. into the drawing that you want to have these same dimstyles, etc.  After inserting, purge out anything you don't want.
Lowell
Message 7 of 9
BillW435
Thanks, Lowell.
Your solution may be easier than the one I used. Apreciate your help.
Bill
Message 8 of 9
Charles_Shade
Templates
Templates
Templates
I'm not sure but using a TEMPLATE requires nothing to be inserted or dragged or found or ...
Message 9 of 9
in reply to: Charles_Shade
I agree, templates are the way to go.  Dimstyles, layers, print settings, etc. all setup in a template and used to start a drawing.  We have a template for a standard 24 x 36 dwg and metric version of the same thing.  We also have a template for an 8 1/2 x 11 sketchpad dwg.  They have evolved a bit since I created my first template in AutoCAD release 2.6 back in the 80's but templates are great once you get all the settings correct for you.
Lowell
Forma Design Contest
Technology Administrators
