AutoCAD LT Forum
I created a dwg file in AutoCAD LT. Today the dwg file is a non Autodesk file.
5 REPLIES 5
762 Views, 5 Replies
Thank you in advance to whomever can solve this problem quickly.
I created a dwg file in Autodesk LT 2020 from scratch. I have imported a pdf file and other blocks from older dwg files into this new dwg. I have saved and reopened this same file several times.
Today, I am getting an error message that my dwg is a non Autodesk DWG. The linework within the drawing is not all visible. I have closed autoCAD and restart the app a few time with no success.  Please help. thanks.
Adrienne
5 REPLIES 5
cadffm
1. This is not an error message, this is a warning.
2. Are you the only one with access to the DWG?
Can you check who saved the file the last time? File properties and DWGPROPS
3. Use a FileExplorer (Windows Explorer?)
Go to this folder and copy the
DWG and <samenameasdwgfile>.bak file.
Hopefuly you didn't saved the file again.
Open the *.bak file by  https://help.autodesk.com/view/ACD/2020/ENU/?query=Drawing Recovery Manager
or rename *.bak to test.dwg and open this file. Old status but content ok?
Command: MODEL
Command: -LAYER
on *
thaw *
Still missing something?
Sebastian
steven-g
Can you post a copy of this "non autodesk" file. How long have you been using 2020 LT is it a fairly recent update, or maybe a trial, or have you used 2020 for some time? Do you have the latest update version 2020.1
TommyBreaux
in reply to: steven-g
Thanks Steven.
I just started using AutoCAD again so 2020 is the only version I have installed. Yes, it is updated to the latest version. I also restarted my computer. the line work appears to have returned to normal but I am still seeing this error message/warning and one additional one. see attached.
TommyBreaux
in reply to: cadffm
Thank you for the reply.
1. ok
2. Yes, I am the only person to access the dwgs.
3. I already did this before asking for help. At first, both drawings (the orig. and the .bak) appeared to have the same warning and only partial linework visible. I restarted my computer which appears to have resolved the weird linework issue of only seeing partial lines in both files. I still see the 'non autodesk dwg' warning in the org. drawing. The issue is resolved in the restored file.
4. I did make sure that all my layers were thawed when the problem first appeared.
I still don't understand why I got the non autodesk dwg message but that is resolved through restoring the back up. I have a new warning message that I tried to resolve but it is still around. I have attached a of that one. Thanks for help.
Adrienne
steven-g
in reply to: TommyBreaux
That's not a warning it's an alert, slight difference ;>) it just lets you know that there is a change in a variable from your 'prefered' settings and mirrtext is a variable that is stored in each drawing individually, so the one you are opening just has a different setting. It would still be interesting to see what Autocad "thought" had created the other drawing, but if you have fixed it then it was possibly just a corrupted drawing file.
Technology Administrators
