Design Center (blocks) - can't find it in 2019
When using 2017, I had something called "Design Center" which gave me all kinds of hardware blocks.
In 2019, I can't find a Design Center, nor any hardware blocks.
Do I have to buy these separate, or am I missing them?
Thank you.
steven-g
Just type 'designcenter' or press Ctrl+2 on your keyboard, the hardware blocks are something that you might have had set up on your 2017 system, what type of blocks?
cadffm
and DC is not part of 'Autocad for MAC'
and you can use [F1] for searching the information in your help.
Sebastian
The blocks that I used in 2017 were simply hardware. Nuts, bolts, washers etc.
I hit ctrl+2 and I see the Design Center, but in the folder for Fasteners - US, for example, there are only about 20 miscellaneous blocks, not the 100's I would see in 2017 with just about every nut, bolt and washer.
I am thinking this might be as you suggested, something that I needed to tell it to install when the software was initially installed.
Update: I think I just found the blocks on my old PC that was running 2017, and brought them over to the new machine that's running 2019.
Looks like it works fine, so I thought I would let you know.
Thank you for your help.
