How to mirror or copy and rotate dimensions for correct text orientation
auhrig
auhrig
How can I copy dimensions from one elevation to another that is rotated on the Z axis in the USC?  When I mirror or copy and rotate, the text in the faces the wrong way.  When I try to rotate in properties, or change the Left-to-Right (or vice versa) any dimensions with a leader become overlapping.  I am trying to find a more efficient way to copy and paste dimensions throughout my drawing, but so that they face the correct directions. TIA
pendean
Community Legend
Community Legend
@auhrig wrote:
...When I mirror or copy and rotate, the text in the faces the wrong way....
Use this variable, set it correctly, and your mirror issue with go away: give it a try
https://help.autodesk.com/view/ACD/2025/ENU/index.html?guid=GUID-D55D2D18-B26E-4525-B5E4-03A2A07FB5F....
See attached, your own file, my mirrored content adjacent, is that what all you want to do?
HTH
auhrig
Unfortunately no,  I have tried this method.  It then moves any dimensions on leaders to an incorrect position that strikes through the dimension text and I can't adjust it to read correctly in any leader position.
