How to erase multiple grid
syanchuck
Message 1 of 13
syanchuck
I have a question about multiple grid. Where it is coming from. It is annoying. How to erase it and/or how to avoid it?
See below:
multiple gridmultiple grid
Replies (12)
Message 2 of 13
RobDraw
If that is AutoCAD's grid, you can turn it off using F7 but that looks more like a graphics problem. Try turning off harware acceleration.
Rob
Message 3 of 13
syanchuck
I do need to use Grid, but I need a right one, not too many.
Trying to turn off Hardware Acceleration. Let's see.
Message 4 of 13
syanchuck
Turning off Hardware Acceleration didn't work, still having sometimes that issue:
That is not only annoying, I have to create the drawing on the grid like that:
So, now I can very easy to deviate from the Grid, what is not acceptable.
I have to mention, that sometimes it is coming, sometimes it is going.
If someone experienced solving that issue, please help!!!
Message 5 of 13
pendean
Community Legend
Community Legend
What triggered this issue: it this a new software installation?
A problem limited to one file?
First time using GRID in AutoCAD/LT?
A recent issue that suddenly appeared?
Your issue appears to be very random: sadly there is no fix for random occurrences.
What does ABOUT command list as your LT version and subversion?
What is your OS?
What are your settings for:
GRIDDISPLAY (System Variable)
GRIDMAJOR (System Variable)
GRIDMODE (System Variable)
GRIDSTYLE (System Variable)
Have you tried to ensure your file contains no issues by fixing it with RECOVER command?
>>>...now I can very easy to deviate from the Grid...<<<
What does that mean to the rest of us exactly?
Is your SNAP setting not the same as your GRID setting?
Message 6 of 13
syanchuck
See my answers in blue:
What triggered this issue: it this a new software installation? - No, it happened since I started working here. No information what was before
A problem limited to one file? - This is a problem for all files
First time using GRID in AutoCAD/LT? - Not
A recent issue that suddenly appeared? - See answer on the first question
What does ABOUT command list as your LT version and subversion? - No answer, will provide soon
What is your OS? - No answer, will provide soon
GRIDDISPLAY (System Variable) - No answer, will provide soon
GRIDMAJOR (System Variable) - No answer, will provide soon
GRIDMODE (System Variable) - No answer, will provide soon
GRIDSTYLE (System Variable) - No answer, will provide soon
Have you tried to ensure your file contains no issues by fixing it with RECOVER command? - No answer, will provide soon
What does that mean to the rest of us exactly? - Not clear what rest of your do not understand. Meaning of "deviate"? Please clarify.
Is your SNAP setting not the same as your GRID setting? - It is exactly the same
Message 7 of 13
syanchuck
Here is the limits of the multiple grids. All grid setting is in line with the rest area:
Message 8 of 13
pendean
Community Legend
Community Legend
We need answers to all the questions I posed: take the time to answer each and every item please.
You can stop posting screenshots in the interim: also ask your new employer about it all, it appears to be a lingering problem they never cared to solve.
Message 9 of 13
syanchuck
Will answer all question. No chance to get anything from my employer, no one is familiar with that here.
Message 10 of 13
ferdi.jafar
Bottom corner of cad click on the arrow of snap mode go to your grid settings. and uncheck the 2D Model Space. If you can not see that arrow on the bottom right there should be 3 lines on top of each other click on it then click on snap mode and the Part A image should appear.
More on here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Auto...Part A.PNGPart B.PNG
Message 11 of 13
syanchuck
I unchecked 2D Model Space: multiple grid disappeared, but now the grid deviated from my drafting. It might be a good idea to set it up when I starting the drawing, however I can't use it with the existing drawing.
I accept your solution anyways.
Message 12 of 13
h_s_walker
If the grid deviates from your drafting, just move the elements of your drawing back onto the grid
Howard Walker
Left Handed and Proud
Message 13 of 13
syanchuck
Since there are electrical drawings, moving everything to the gird is a not a good idea. Some of the object's coordinates have been registered already.
