Greetings @cb94030
Any reason you don't want to use the 50+ possible icon toolbar right there at the top of the Ribbon called QAT that you can add anything you want to anytime and it stays there all day long? I have it positioned at the bottom of the Ribbon where I like it to be:
That you can drag and drop your custom commands created in CUI command's pop-up section called COMMAND LIST to literally with your mouse button
or if that command already exists in the Ribbon, you can right-click on it and have it moved to that QAT toolbar
and you can arrange the locations of the items in the QAT with a drag/drop while in CUI command
@cb94030 wrote:
Maybe we cannot do it with ACAD LT?
Or something else, here is more info and tutorials online if you still truly want to use old-school toolbars instead of taking advantage of the QAT that is right-there and ready to use https://www.google.com/search?q=autocadlt2023+tip%3A+how+to+create+a+toolbar
HTH
