How to create a new toolbar
cb94030
cb94030
I have ACAD LT 2023.
I don't see how to create a new Toolbar where I can place my most used commands.
Maybe we cannot do it with ACAD LT?
Thank you
Chris
paullimapa
Try following this video tutorial similar in LT
https://m.youtube.com/watch?v=e0kza0yil0M
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
Greetings @cb94030
Any reason you don't want to use the 50+ possible icon toolbar right there at the top of the Ribbon called QAT that you can add anything you want to anytime and it stays there all day long? I have it positioned at the bottom of the Ribbon where I like it to be:
That you can drag and drop your custom commands created in CUI command's pop-up section called COMMAND LIST to literally with your mouse button
or if that command already exists in the Ribbon, you can right-click on it and have it moved to that QAT toolbar
and you can arrange the locations of the items in the QAT with a drag/drop while in CUI command
Or something else, here is more info and tutorials online if you still truly want to use old-school toolbars instead of taking advantage of the QAT that is right-there and ready to use https://www.google.com/search?q=autocadlt2023+tip%3A+how+to+create+a+toolbar
HTH
cb94030
Thanks a lot!!!!!!!!
ichisdeno
Community Visitor
Community Visitor
my class is using the program and other people has been messing with it making it look different and my teacher wants to change it back but when i tried to fix it i some how managed to remove the bar. can anyone help me with this?
h_s_walker
@ichisdeno from an old post on here
1) Open the CUI (type CUI at the command line)
2) In the top left window, highlight your workspace
3) In the top right panel, click "Customize"
4) In the top left panell, click the "+" symbol next to Quick Access Toolbar
5) Put a checkmark in the box
6) Click "Apply" and "OK" at the bottom of the CUI palette.
Or if you are talking about the toolbars at the top at the command line type RIBBON
Howard Walker
Left Handed and Proud
