AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
How do I display a secondary measurement in the Properties pallette?
3 REPLIES 3
vik_m
251 Views, 3 Replies
Hi guys,
Can anyone show me how to add a secondary unit of measurement in the properties palette? Like the one shown in the image above - the measurement in parenthesis (square ft.) The image was taken from a file that has inches for its Unit. The image shows the property of a selected hatch in the drawing.
My AutoCAD LT is only showing this:
This is the property of a hatch that is selected in the drawing. I am working in millimeters and I was wondering if I can have the area shown in square meters as well like the above image.
Thanks!
3 REPLIES 3
paullimapa
in reply to: vik_m
Nope, that could only happen when UNITS is set as Architectural & Engineering which are both Foot Inch (Imperial) measurements.  Unfortunately, AutoCAD does not have a true metric unit of measurements so the default of Decimal units doesn't quite do the trick.
Paul Li
IT Specialist
@The Office
vik_m
in reply to: paullimapa
I see. Maybe that is why I was not able to find any "solution" to this when I was snooping around. Thank you, Paul!
paullimapa
in reply to: vik_m
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Technology Administrators
