Hi guys,
Can anyone show me how to add a secondary unit of measurement in the properties palette? Like the one shown in the image above - the measurement in parenthesis (square ft.) The image was taken from a file that has inches for its Unit. The image shows the property of a selected hatch in the drawing.
My AutoCAD LT is only showing this:
This is the property of a hatch that is selected in the drawing. I am working in millimeters and I was wondering if I can have the area shown in square meters as well like the above image.
Thanks!
Solved by paullimapa. Go to Solution.
Nope, that could only happen when UNITS is set as Architectural & Engineering which are both Foot Inch (Imperial) measurements. Unfortunately, AutoCAD does not have a true metric unit of measurements so the default of Decimal units doesn't quite do the trick.
Glad to have helped…cheers!!!
