I need to bind a pdf into a drawing so that I can email the drawing without losing the path. I'm currently using 'ATTACH' the pdf from file and selecting 'no path'. Each time I email a .dwg I lose the pdf. Help greatly appreciated!
Solved by pendean. Go to Solution.
No binding for PDFs.
You can capture snapshot images of them and attach pictures of the PDFs if you want to go that route: use the snapshot tool in your PDF Reader, then CTRL+V in AutoCAD. Or use another tool to export the PDF to a raster image that you can insert into AutoCAD with INSERTOBJ command.
The quality of the images will not be on par with the quality of the PDFs.
When you send DWG files, get in the habit of using ETRANSMIT command: and if your recipient really wants the PDFs, that tool will bundle those with the DWG file into a neat ZIP file. It's the better way to share DWG files.
Thanks so much for the advice. The pdf is a business logo so I really want to keep the quality. Are there an alternative way to keep the quality? Thanks for the heads up on emailing too.
