AutoCAD LT Forum
How do I bind a pdf into a drawing so that I can email without losing the pdf?
4 REPLIES 4
38006 Views, 4 Replies
I need to bind a pdf into a drawing so that I can email the drawing without losing the path. I'm currently using 'ATTACH' the pdf from file and selecting 'no path'. Each time I email a .dwg I lose the pdf. Help greatly appreciated!
4 REPLIES 4
pendean
No binding for PDFs.
You can capture snapshot images of them and attach pictures of the PDFs if you want to go that route: use the snapshot tool in your PDF Reader, then CTRL+V in AutoCAD. Or use another tool to export the PDF to a raster image that you can insert into AutoCAD with INSERTOBJ command.
The quality of the images will not be on par with the quality of the PDFs.
When you send DWG files, get in the habit of using ETRANSMIT command: and if your recipient really wants the PDFs, that tool will bundle those with the DWG file into a neat ZIP file. It's the better way to share DWG files.
in reply to: pendean
Thanks so much for the advice. The pdf is a business logo so I really want to keep the quality. Are there an alternative way to keep the quality? Thanks for the heads up on emailing too.
pendean
Create a high quality raster image of the logo (where the PDF came from) and experiment with bringing it in: to maintain quality, you want to ensure the raster image is as large a size as possible so you avoid scaling it up inside AutoCAD.
Best way to bring a raster file in IMHO: open it in a graphics application that will let you "select all" and "copy" the image, then in AutoCAD/LT use PASTECLIP (CTRL+V) command to paste it where you need it. Do NOT resize it to be bigger.
Thanks I'll give it a go. Appreciate the quick and thorough response.
Technology Administrators
