I have AutoCAD LT 2014 and i have a drawing that i attached a picture to and have a few hatches over. When i go to PDF it and print the drawing it has green lines throughout and not just on the part of the attachment but over the entire page. How do i get rid of these? I dont see them in AutoCAD
I FIGURED OUT A WAY AROUND THIS! I had the same problem when printing out a single pdf. But when I used BATCHPLOT it worked!
I enlarged the viewport to put the entire pdf in it and, when printed with Acrobat, the green lines were gone so, my problem evidently has something to do with the viewport clipping the pdf. As of this date, I have not discovered exactly what it is. When I changed the plotter from Adobe PDF to DWG to PDF, the problem also disappeared. It is likely that it is an issue between Autocad and Adobe Distiller. I am not aware if it has been resolved.
Just to double check your steps, have you clicked the pdf and selected "remove clipping mask" then used the viewport on the sheet itself to define what is seen when you print?
