AutoCAD LT Forum
Green lines when pdf
24 REPLIES 24
Message 1 of 25
16259 Views, 24 Replies
I have AutoCAD LT 2014 and i have a drawing that i attached a picture to and have a few hatches over. When i go to PDF it and print the drawing it has green lines throughout and not just on the part of the attachment but over the entire page. How do i get rid of these? I dont see them in AutoCAD
24 REPLIES 24
Message 21 of 25
I FIGURED OUT A WAY AROUND THIS! I had the same problem when printing out a single pdf. But when I used BATCHPLOT it worked!
Message 22 of 25
I enlarged the viewport to put the entire pdf in it and, when printed with Acrobat, the green lines were gone so, my problem evidently has something to do with the viewport clipping the pdf. As of this date, I have not discovered exactly what it is. When I changed the plotter from Adobe PDF to DWG to PDF, the problem also disappeared. It is likely that it is an issue between Autocad and Adobe Distiller. I am not aware if it has been resolved.
Message 23 of 25
pendean
"adobe PDF" is not an Autodesk provided driver: it tends to be a legacy driver (if you opted for the migration tool) or a third party offering on your PC (from Adobe in your case).
Adobe support would be the place to ask, but honestly, they may not know either.
Message 24 of 25
Just to double check your steps, have you clicked the pdf and selected "remove clipping mask" then used the viewport on the sheet itself to define what is seen when you print?
Message 25 of 25
wolfman00100
that worked for me
thanks
Forma Design Contest
Technology Administrators
