AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Forcing dimension arrows outside of extension lines?
8 REPLIES 8
Message 1 of 9
16257 Views, 8 Replies
Is there a way to force the dimension lines and arrows outside of the
extension lines? I see you can force them inside, but I haven't found a way
to force them outside.
Dave
AutoCAD LT 2002
8 REPLIES 8
Message 2 of 9
Not an option.
FM
Message 3 of 9
BearsFan
To force an arrow that is on the inside to go to outside (shown below)
|<---dimension--->|
to
-->|---dimension---|<--
1. highlight the grip point at the arrow.
2. wait about 5 sec.
3.  When menu pops up, select "flip arrow"
Unfortunately this only does one side so you must rinse and repeat on other side.
This works to flip from outside in as well
to
|<---dimension--->|
Message 4 of 9
in reply to: BearsFan
This stuff works.. thanks man
Message 5 of 9
This works - but I'd like to have the dimension line not appear between the extension lines:
I'd prefer     ---->|   Dim.Text   |<----
not ..             ---->|--Dim.Text--|<----
Is this possible? Years ago I wrote a LISP routine (that I lost when changing employers) that would cycle through all of the arrow-in/arrow-out options for a chosen linear dimension. So, in those days the result shown above was possible - but I'm not sure how to achieve it now.
Thanks!
Oops, I found the above solution via a Google search and didn't realize that this was on the LT (versus AutoCAD) forum - until after I'd posted. Assume the answers might be the same for both platforms..?
Message 6 of 9
pendean
It works in all variants of AutoCAD.
Message 7 of 9
in reply to: pendean
Thanks for that variant verification - I appreciate it.
Do you know how to eliminate the dimension-line segments, that are between the extension-lines, when the arrows get flipped to the outside?
Such that ...
we have   --->|   XXX.XX  |<---
and not   --->|--XXX.XX--|<---
Message 8 of 9
select Dimension in question then go into Properties and increase "Text Offset".  may need to re-flip arrows afterwards.
Message 9 of 9
Thanks. A bit clunky way that they've designed for making this simple change - but it works.
Thanks for your help!
Forma Design Contest
Technology Administrators
