Hi all,
I'm having an issue when designing dynamic blocks. I have looked through the forums for help but I've unfortunately come up dry. (I'm new to this, so it may very well be the way in which I am phrasing the question)
One of the main features of the blocks that I want to include is the option to align them together. I want to align them in a standard manner with a constant offset between them (5mm).
So far I have added an alignment parameter offset by 5mm to one side of the block. I have set the type to both tangential and perpendicular. It works perfectly when aligning to a line in the drawing however, when aligning to another block it doesn't work (no rotation).
I'd greatly appreciate any help and insight into the matter.
Daniel.
