AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Drawing Preview
9 REPLIES 9
Message 1 of 10
chandratigerbuckets
387 Views, 9 Replies
Drawing Preview
While opening the DWG file it does not show drawing preview.
I have uninstalled and reinstalled latest version for Autocad LT but still problem is not resolved.
Please help.
9 REPLIES 9
Message 2 of 10
You need to set up your thumbnail preview. See the link and image below
AutoCAD 2017 Help | Thumbnail Preview Settings Dialog Box | Autodesk
Howard Walker
Left Handed and Proud
Message 3 of 10
Still problem remains the same.
I made changes as per instruction but no result
Message 4 of 10
"While opening the DWG file it does not show drawing preview."
I can't understand. WHILE opening? Guessing the same as hwalker, you mean a preview-image while you are
in OPEN dialog (or where?) and not while ACAD opens a file.
While this option is enabled, save a DWG(!) file, close the file and test it again.
If we are off the track, show us what you are talking about (Screenshots and further descriptions)
Sebastian
Message 5 of 10
FYI
Message 6 of 10
@chandratigerbuckets No screenshot is attached. See the image below for the icon to use
Howard Walker
Message 7 of 10
[image: image.png]
Message 8 of 10
again - no image 😞
Try this way:
Starr [Reply]
Look below the Text-box, BROWSE...
Sebastian
Message 9 of 10
Hi
I have uninstalled and reinstalled  Autocad LT 2024 but still problem is not resolved.
Please help.
Thank you.
Tags (1)
Message 10 of 10
If I see the file icon in Windows Explorer, it seems that the DWG file is not associated with AutoCAD as the default program.
Follow this instruction to associate the file: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/DWG-file-type-asso...
And see if it fix the problem.
Cheers,
Edwin Prakoso
Forma Design Contest
Technology Administrators
