While opening the DWG file it does not show drawing preview.
I have uninstalled and reinstalled latest version for Autocad LT but still problem is not resolved.
Please help.
You need to set up your thumbnail preview. See the link and image below
AutoCAD 2017 Help | Thumbnail Preview Settings Dialog Box | Autodesk
Howard Walker
"While opening the DWG file it does not show drawing preview."
I can't understand. WHILE opening? Guessing the same as hwalker, you mean a preview-image while you are
in OPEN dialog (or where?) and not while ACAD opens a file.
While this option is enabled, save a DWG(!) file, close the file and test it again.
If we are off the track, show us what you are talking about (Screenshots and further descriptions)
Sebastian
@chandratigerbuckets No screenshot is attached. See the image below for the icon to use
Howard Walker
again - no image 😞
Try this way:
Starr [Reply]
Look below the Text-box, BROWSE...
Sebastian
Hi
I have uninstalled and reinstalled Autocad LT 2024 but still problem is not resolved.
Please help.
Thank you.
If I see the file icon in Windows Explorer, it seems that the DWG file is not associated with AutoCAD as the default program.
Follow this instruction to associate the file: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/DWG-file-type-asso...
And see if it fix the problem.
Cheers,
Edwin Prakoso
