AutoCAD LT Forum
Draughting 2D
10 REPLIES 10
Message 1 of 11
668 Views, 10 Replies
Draughting 2D
Hello Community,
I have opened a large floor plan - half of the blocks (door, windows) are showing at a much smaller scale.
Is there a way to change their size globally?
GSD
10 REPLIES 10
Message 2 of 11
Charles_Shade
WBLOCK a piece of your drawing and post it here if you cannot or are not allowed to post the entire file.
Also, any Imperial to Metric scalng going on with your work?
Message 3 of 11
pendean
And what scale is that? Use DIST or PROPERTIES command and figure out if there is a scale or size that may give you a clue about why that is the case and how to fix it.
PROPERTIES command is the place to also fix these "scales".
Message 4 of 11
in reply to: Charles_Shade
Hello Charles,
I trust this is what you need - the base dwg has a long history (of abuse?)
I've been tempted to start from scratch.
There could well be conversions from Imperial to metric previously.
Thanks for your interest.
Gray Swain
Mob: 07913 781 496
E-mail: grayaswain@gmail.com
Message 5 of 11
in reply to: pendean
Hello 'pendean',
Thank you for your interest - can we have an hiatus on comms for now. I no
longer use the defpoints layer and yes there may well be a scaling issue at
the base of this. I will revert.
Kind regards,
Gray Swain
Mob: 07913 781 496
Message 6 of 11
Charles_Shade
If you meant to post something there is no attachment
Message 7 of 11
I'll try again Charles. g
Message 8 of 11
Hello Charles,
Attached is portion of the dwg in query - trust it serves the purpose.
Gray
Message 9 of 11
pendean
You did not do as I suggested, actually measuring anything, did you 😞  You could have solved this on your own.
Your metric walls (it should be 100mm, but in your file, 8'-4" wide) have 36mm doors in them (these should be 36" doors).
Your file is a bad scaled mess, it's an Metric plan inside an Imperial scale DWG file where the plan was not scaled correctly.
AutoCAD only understands UNITS as, well, nothing but UNITS. we humans determine if a unit is mm or inch or mile. Rescale your file to be Imperial scale if you work in inches, or change the scale of your doors and windows to be in mm and not inches: explore using -DWGUNITS command to fix it.
Message 10 of 11
Hello Dean,
Thank you for this - I can appreciate your frustration - although I did not take any measurements I was aware of the mixed scaling problem but did know really whwere to start.
So armed with your advice and the tools you have indicated I can proceed to sort out the dwg.
Sadly this is a hugh base plan, probably pre-2004, which was clearly set-up as imperial with efforts made over the years to convert to metric.
We are working in metric, so wish me luck.
Kind regards,
Gray
Message 11 of 11
pendean
No frustration intended my friend, just pointing to the obvious, if you read more than that in my reply I do apologize.
Measuring items in the file, vs assuming they are correct, is the #1 thing you must engage in to identify problems like these. Hopefully you will do so moving on.
Forma Design Contest
Technology Administrators
