AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Distance command on toolbar
3 REPLIES 3
514 Views, 3 Replies
I just installed AutoCadLt2021 and I can not figure out how to make my tool bar save the Measure-Distance command.  When I change it to distance and close out and the re-open autocad the toolbars shows the Quick command.  I tried going to Tools-Workspace-Save As Current but that didn't work.  Is there a way to save the toolbar so that the distance command is saved?
Thank you
3 REPLIES 3
pendean
WE can't see your screen so we don't known what exactly you did, where, and how you saved it.
Post a bunch of screenshots or a video of your actions, lets see what you see and do.
Or read this (you also want the command DIST, not whatever else you might think you need) https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Au...
in reply to: pendean
Measure - QuickMeasure - QuickMeasure-DistanceMeasure-Distance
When I open autocad the Measure-Quick option is defaulted.  I can change it to Measure-Distance but I can't figure out how to save it to my toolbar.  When I close acad and reopen it, it defaults back to the measure-quick command.  I would like it to open with measure-distance.
pendean
It only remembers your sub-choice while in the same session: closing/restarting the program resets it. That is by design.
Why don't you just add DIST command to the QAT bar, use CUI command to drag and drop it there https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
Technology Administrators
